My coolant tank was empty and there was a plastic cane in the cockpit/dashboard, so I thought, it was water and I put some in the coolant tank. I am pretty sure it was less than 500ml.
Driver is using the vehicle, and it seems to working, engine/motor doesn't sound anything suspicious for 4 days.
Should I worry?
Does the motor has to be opened for clean up?
    I'd just swap coolant for a couple of times and don't worry too much about it
    – Martin
    May 19, 2022 at 7:36
  • Sorry, I didn't get what you mean by swap coolant? Like clean the coolant?
    – Phoenix404
    May 19, 2022 at 7:38
  • 4
    Just drain the contaminated coolant, refill with fresh one and drive for a while to dilute the remaining contaminations. Repeat this for two or three times..
    – Martin
    May 19, 2022 at 8:32
    ok, This has been done after 100 - 110 km run.
    – Phoenix404
    May 19, 2022 at 9:58
9
ADBLU is a mix of uric acid and water, and you don't want acid in your cooling system as it can cause corrosion. It's not a disaster, you just need to drain your coolant out of the system and refill with fresh coolant.
From your other question it seems like you have a cooling system problem and are losing a lot of your coolant every day. If this is the case I wouldn't worry about it as a mechanic is going to do this anyway to fix your other problem.
  • yea, but which mechanic. I mentioned two mechnics and they are saying completly different things.
    – Phoenix404
    May 19, 2022 at 10:00
  • 3
    Either of what they say will require draining the coolant
    – GdD
    May 19, 2022 at 10:02
  • do warn them there may be contaminated coolant, however!
    – ti7
    May 19, 2022 at 22:22
