2011 Ford Escape 3.0 FWD. System has charge, no leaks, new expansion valve. Compressor fuse was removed. When turning on the AC. The fan did not kick on and compressor did not activate. Both fans turned on low only when temp was reached. Here's what I did:
I unhooked three wire connector at the accumulator in hopes to jump the connector to see if I could get the compressor to turn on. When I seen there were three wires with no diagram I decided to check the relay, but I forgot to plug the connector to the accumulator back in. I swapped relays and the high speed fan kicked in as it should. I got a little excited that it worked but the compressor didn't kick in. Then I noticed the accumulator connector was unplugged. I plugged it in and fan turned off and no compressor. In plug it the fan kicks in. Anyone know where to go from here?
