Based on this: How to fix overboost for VW Tiguan 2009?
The service said that the air is controlled electronically in the turbine. And because of electronic failure, I might be getting the overboost error. Is that true? I watched this https://www.youtube.com/watch?v=pn-uCAgB4H8&ab_channel=EngineeringExplained and there it shows that this is controlled using spring. Maybe in tiguan is different.
If they are controlled electronically - then how they are checked? Need to attach to the turbocharger?
    I believe you asked a very similar question already and appear to have abandoned it. but the video is a general explanation of how turbocharging works and you're trying to use it as a specific troubleshooting guide for your vehicle.
    – jwh20
    May 11, 2022 at 16:50
  • From the similar questions I did not get enought information, I am not sure what to do
    – Darius.V
    May 12, 2022 at 17:47
