Despite the use of threadlocker being somewhat widespread (e.g. repair videos), I have yet to see a single recommendation to use it in any service manual. Perhaps this is my relative inexperience, but I thought I'd ask the community out of curiosity - do you use threadlocker? If so, what is your criteria for deciding which bolts receive threadlocker and which ones do not?
It depends on the vehicle but it's not uncommon to see threadlocker specified for assembly.
Use threadlocker when it's called for. Today many modern vehicles use one-time-only fasteners instead of threadlocker so it may be less common now than it was in the past.
I use threadlocker when the service manual says to, I replace fasteners when called for, and I just torque to spec when that is all that is specified.
  • I'm not quite sure where you're coming up with a correlation between using threadlocker and one-time-only fasteners? Apr 30, 2022 at 23:40
    I've known of some people who will reuse one-time fasteners and assume that if then just put threadlocker on them it will be ok. That's NOT the case. But some folks just do what they want.
    – jwh20
    Apr 30, 2022 at 23:43
  • One-time-fasteners are usually torque-to-yield, which don't use threadlocker. Apr 30, 2022 at 23:46
  • @jwh20 Ahh ok. I guess it's just the cars I've worked on in which I've seen no mention of threadlocker in a manual.
    – TLex
    May 1, 2022 at 0:36
  • @Paulster2 - Only other one-time fasteners I can think of are exhaust bolts/studs, but I also haven't seen threadlocker prescribed for those.
    – TLex
    May 1, 2022 at 0:40
The main places I have seen the required use of Threadlocker or Retaining Compound (e.g. Loctite 638) specified in a car repair manual is on the splines of driveshafts.
I have also seen a band of threadlocker already in place on new bolts that are used to hold brake callipers on.
  • Damn, well that makes it easy.
    – TLex
    May 2, 2022 at 10:03
