Hello I have a 2012 F150 that the brakes constantly get hot on the left front side. The rotors and brake were recently replaced, but this issue seems to be ongoing even with the older brake and rotor set I had on. The wheel is also tighter to turn when it's on a jack and takes two hands to spin it vs the right side that freely spins
When the old set was new it got hot and smoked, and I had to replace a crimped line and it seemed okay but would shutter when braking and I just drove it that way for awhile. I had a new set to replace that set and the same side is getting warm and I want to try to figure out the issue before I have the same thing happen.
I replaced the ball joints on the left side last fall, would an alignment issue cause brakes to stick on one side as well possibly?
