Okay so this happens like almost every summer/ spring . My car suddenly won't move. I can shift gears normally . It just won't go past 30 kmh or 60 kmh and if it goes it starts to slow down and not take any gas . Anyone might know the problem?
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Apr 2, 2022 at 12:21
1Is the check engine light on? It could be a number of things - clogged fuel filter, bad fuel pump, dirty Mass Airflow sensor, dirty engine air filter, malfunctioning Throttle Position Sensor. There are other potential causes, but these are the ones I would check first.– MJHApr 2, 2022 at 16:20
Diesel or petrol?– Vladimir DjuricicAug 9, 2022 at 17:56
