The battery is not charging, and when I use an ohms meter between the alternator output terminal and the battery +, I read 7.5 ohms. When the motor is running I see 14.45v between the alternator terminal and ground. Rather than mess about with wiring looms etc. I would prefer to run a new cable from the alternator to the battery. Are there any issues I should be aware of?
Edit I found the diagrams and there looks to be a fuse needed.
Jeep Patriot 2.0 litre diesel, 2007
