I have replaced the relay in the dash. Also replaced the combination lever on the steering wheel and also put brand new tail lights in with new bulb sockets and lights. Nothing works. Another problem is when I hit the brake pedal the fuse for the brakes blow. Not sure if they are related
Welcome to Motor Vehicle Maintenance & Repair! When you press the brake pedal do the brakes blow, or does the fuse for the brake lights blow?– Pᴀᴜʟsᴛᴇʀ2 ♦Mar 26, 2022 at 23:06
I get it ... no I don't. Wait. Oh, OK.– John CanonMar 27, 2022 at 3:09
There's probably a short in the wiring which is what's causing the brake fuse to pop and the turn signals to not to blink.– FreeManApr 8, 2022 at 16:32
