I recently bought a new family sedan which comes with the hard stock tires. Now I am worried whether they could reduce the life of suspension parts in near future. Should I change the stock tires to some good quality soft ones?
  • What do you mean by "hard"? Hard material (rubber compound)? Stiff sidewall? High pressure? What makes the stock tires harder than a soft tire? Feb 25, 2022 at 13:01
  • @Pᴀᴜʟsᴛᴇʀ2 it's hard rubber compound I guess because the ride feels bumpy with the recommended tire pressure.
    – ifadey
    Feb 25, 2022 at 13:09
  • I've never heard of "hard" vs. "soft" tires. It might help if you updated your question with the specific brand and model of tires you have and are considering.
    – jwh20
    Feb 25, 2022 at 13:36
If the ride is hard it's not because of the tire compound, changing to a different brand isn't going to improve things. Tire compounds effect your grip on the road, not your ride. If your ride is hard it may be because:
  • You have run flat tires: run flat tires are stronger as they have to provide rigidity after a loss of pressure, so they have a harder ride. You could change to regular tires, but you'd have to change the rims in most cases
  • Over-inflated tires: check to make sure you haven't put too much air in
  • Worn suspension: old shocks and bushings can give a hard ride, if it's a used car you may want to get that checked (The post says new car so I'm adding this for completeness if others have the same issue)
  • The car is designed for a harder ride: Different makes go for different rides as harder is 'sportier', with a BMW sedan you'll feel every pebble in the road whereas a Lincoln Continental will have much more 'float'
As for damage, if a car is designed for a harder ride then the components will stand up to it.
  • Another cause of ride hardness (compared to a previous vehicle) is different tires with a lower aspect ratio. When the wheel rim and the ground are closer together, there's less rubber and air to absorb impacts. Feb 25, 2022 at 21:40
