Posting on behalf of a friend. She bought a used 2020 Toyota Corolla from carvana a few months ago. Yesterday she called me saying the dash threw a hood unlatched warning and the hood latch was actually open. We fixed it easily by opening and closing the hood, but why did this happen?
She had no reason to open the hood when she owned the vehicle
Could she have accidentally hit the latch release with her leg?
Could it be an act of vandalism when she left her car unattended?
Just want to make sure this is a one off thing or if its a symptom of a bigger issue
It could be that it just wasn't latched all the way and finally popped. I've seen weird things like this happen. If it happens again, I'd suggest the latch needs to be adjusted to ensure it's fully engaging correctly, or possibly the latching mechanism is worn out and might need replaced.
Most modern day hood latches take quite a bit for them to be overcome by nefarious means. Also, hood latch pulls are designed so you have to purposely engage it for it to unlatch the hood. There's just about no way for someone to accidentally do this by bumping it with their knee or something similar.
It's possible someone at Carvana was in there inspecting it, and didn't latch it all the way when they closed it. I'd consider it "no big deal".
Any hood will have a secondary latch, which will prevent it from opening more than a few inches even if it pops open. You must reach in and release the secondary latch to get it to open further. That's a safety feature.
  • I don't understand why you're being so dismissive and insulting. Idk where you even got the idea that I'm proud of not opening the hood or me not knowing where the washer fluid goes. -1 for that. All I meant that we didn't have to open the hood from delivery time till now so an improperly closed hood latch wasn't from our side
    – rsn
    Feb 25, 2022 at 1:33
  • While I wouldn't give this answer any glowing reviews, I also wouldn't state it is rude or abusive. The answer given is the truth and therefore may seem a little stern. It could definitely be written better. The only part of it which leaves me wondering is "Carvana" ... no clue where that came from. Feb 25, 2022 at 10:52
  • @rsn fair enough; withdrawn. Feb 25, 2022 at 19:17
  • @Pᴀᴜʟsᴛᴇʀ2 I mentioned carvana in my question
    – rsn
    Feb 26, 2022 at 21:42
  • @rsn - My mistake. You know, I read your question at least four times and didn't see it. Must be going blind. Feb 26, 2022 at 22:30
