2010 Sante Fe, high beam on passenger side not working but all other lights work. Checked fuses all good. Put meter on connector to high beam, shows no power to that connector. Where would the break be?
  • Have you checked the fuses?
    – HandyHowie
    Feb 12, 2022 at 21:18
  • Welcome to Motor Vehicle Maintenance & Repair! Did you swap the bulbs out just to absolutely make sure it's not the bulb? Feb 12, 2022 at 21:41
  • Paulster cha'd bulbs first, then put meter on connector-no power to bulb, Howie-checked fuzes next all good.
    – E from FL
    Feb 13, 2022 at 2:24
