2017 i20 petrol manual.
For the past week it has felt very hesitant when pulling off in first gear. It feels like it will stall ( though it doesn't), shuddering.
2nd gear can have the same issue too if going at very slow speed (less than 10mph)
No engine lights are on. Any ideas what might be the cause?
The issue started right after getting an MOT, not sure if that is coincidence or related
Thanks in advance
Edit : it also seems to be a bit worse when the car is cold, and gets a little better as it warms up.
Adding a bit more gas and just lifting the clutch as normal reduces the shuddering, and it doesn't stall
