I'm watching this video, "Front Strut Replacement 9th Gen Honda Civic 2013" and they say,
"On this particular Honda Civic there is no camber adjustment or caster adjustment the only adjustment is toe-in toe-out camber is set to 0 degrees from factory there are no camber installed in those pinch bolts therefore camber in theory should not have moved"
Does this mean there is no way for a professional to adjust camber or caster the Honda Civic? I learned from this answer there are three types of alignment. If there is really is no method to do camber and caster adjustment, should I just ask for a quote to do toe-in and toe-out?
