In this video, "What are Shocks? What are Struts? Which Does Your Car or Truck Use?" the narrator says,
One thing I strongly recommend is if you get the assembly get the links, the links are attached to the assembly. [...] They wear real fast.
In this question I was told the link in question is called an "end link for a sway bar". Is it necessary to replace the end link for the sway bar on a strut replacement. Is this also a Honda recommendation or common place? Is it easy to replace the end link for the sway bar later if needed?
