Does not pick up speed for a couple seconds. I changed the throttle sensor about a year ago when I had the issue and the problem went away for a while. There is also a check engine light and flashing cruise light as well.
  • Welcome to Motor Vehicle Maintenance & Repair! When you replaced the throttle sensor, did you perform a "relearn" on it? Jan 2, 2022 at 20:12
