I have a 2011 ford fiesta 1.6l manual 5 speed. My speedometer is working good but odometer and all other attached infos like the shift light, the miles per gallons or distance left to empty does not work. I bought the transmission speed sensor but cant locate it. Any ideas where it should be?
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Dec 20, 2021 at 3:19
Do you mean ‘odometer’ or ‘tachometer’?– HandyHowieDec 20, 2021 at 8:23
If the speedo is working then a transmission speed sensor is unlikely to correct the problem. Sounds like an ECU issue to me. The transmission speed sensor sends a signal to the ECU which then calculates all the other things you mentioned and displays them.– jwh20Dec 20, 2021 at 14:54
Is this related to mechanics.stackexchange.com/questions/55866/…?– zipzitDec 20, 2021 at 21:45
