My car doesn't have a front central lifting point according to the service manual, and this diagram suggests any front chassis members are obscured by a cover.
Is it safe to lift the car one side at a time from the rear pinch welds, and put axle stands under the front pinch welds, as per this video? I'm concerned that when jacking the other side, the car will be supported diagonally across a front and rear pinch weld on opposite sides. It sounds unstable, or it might tilt the wrong way with the weight of the engine.
The aim is to remove the front wheels to bleed the front brakes. I don't believe I need to go under the car with the front wheels removed, so alternatively I could consider supporting the front pinch welds on locking trolley jacks.
