My battery died, and after the jump start the Infotainment touchscreen (radio, cd, GPS, etc) console won't turn on. I suspect the fuse might be burnt. Which fuse is assigned to the Infotainment console system? Also, would be great if you can share the fuse diagram as well.
2Have you checked the fuse box covers? there is often a legend given either molded into the plastic or a paper stuck on. If not what about the owners manual - that usually has the information.– Solar MikeNov 4, 2021 at 6:28
Nothing in the manual. I have the repair manual and couldn't find it there either.– KingsInnerSoulNov 14, 2021 at 18:24
