Is there anyway I can raise my expedition running boards manually? A fuse blew and there's no electricity going to the board anymore, thanks in advance
  • I'm not seeing the connection between raising your running boards and a blown fuse. Why don't you just replace the fuse? Perhaps you might edit your question so that your issue is more clear.
    – jwh20
    Commented Nov 3, 2021 at 12:33
  • Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking.
    – Community Bot
    Commented Nov 3, 2021 at 14:08
  • Some things like that have a square on a shaft to enable it to be turned manually. I suggest you have a look - may even be a "socket" on the gear, motor or shaft end. But if you provided some photos of the system that might help.
    Commented Nov 3, 2021 at 14:32
  • If your fuse is blowing immediately when you install a new one, that means you have a short somewhere you need to resolve. Could be a power wire that's got the insulation rubbed through and is now contacting the frame, or a plethora of other issues. Resolve that issue, replace the fuse and things will work normally again. Commented Nov 3, 2021 at 15:45
