https://www.amazon.com/2-Pack-Trailer-Wheel-ST205-75D14/dp/B074MHFC2C/
Said tire is rated:
  • Tire Weight Rating: 1760 Lbs. Max. Pressure: 50 PSI
Does this mean that one pair of tires (on a single axle) can support 2X1760 lbs?
Basically, yes. However, there is the rating of the axle itself to consider. The axle, more or less, will have a different rating. Make sure you take into account this before you decide whatever you're putting the tires onto might be able to handle the load.
  • Always grateful to hear from @Paulster2's insight. Thank you
    – gatorback
    Oct 14, 2021 at 3:34
