On an outboard two stroke engine, what tests can I do with a compression tester, (and how to carry them out)? It's a Yamaha 200 hp V6 2-stroke boat engine.
Compression testing a 2-stroke engine is no different than doing it on a 4-stroke. What part of the process are you asking about?– jwh20Sep 30, 2021 at 16:40
@jwh20 - for example, checking the rings - 4 stroke, put oil in cyinders, turn over. With valves in the bores, how could I do that?– TimSep 30, 2021 at 18:00
The oil test part of a compression test only happens if you find the compression low. Putting some oil in the cylinder, which you can easily do on a 2 stroke (it only takes a small amount) will help the rings to seal. So if that helps, then you know that the rings are most likely the problem. Otherwise it's likely a valve (not in this case) or a head gasket leak.– jwh20Sep 30, 2021 at 19:50
Since 2-stroke engines don't use overhead valves but have ports near top dead center. compression will be different than 4-stroke engines using ohv. Here's one link for an approximation of compression values; marineengine.com/boat-forum/…– F DryerSep 30, 2021 at 23:15
@FDryer - many thanks for the thread - it's very useful !– TimOct 1, 2021 at 7:35
1 Answer
As is said here 2-Stroke Squish & Compression Testing
The Best Way to get a Valid Compression Reading
A) Within 5 days of a normal “operating cycle - Engines that have sat for a long time may have excess oil that has leaked in from somewhere. The added ring sealing offered by this excessive oil presence can greatly increase the normal valid reading.
B) Cold Engine only - Hot engines will yield lower numbers, and varying levels of temperature will yield varying levels of lowered readings.
C) Fuel Petcock “off” - To avert fire risks.
D) Throttle “must” be full open - To consistently allow the same air access to the lower end.
E) Spark plug mounted in cap and grounded to motor (to avoid harming ignition)
F) Put your machine in 1st or 2nd gear (use the same gear each time), and push the bike at a walking speed for about 10 feet (road-racers with very tall gearing should go 20ft). Doing the test in this way assures that the engine will always spin at the same speed, and that gauge gets enough "pressure hits" from the cylinder to correct for a gauge that may have an unusually large volume hose.
G) Repeat - It’s not a bad idea to do two or three tests (back to back) to assure consistency
I have tested 2 engines following this guide, but never marine ones
