2008 Subaru WRX (Turbo) I was pulling in to my parking spot and lost power steering looked at gauges and coolant temp was hot then white smoke/vapour from under the hood. Turn car off, pop hood and coolant sprayed all over engine bay but mainly seems around the reservoir.
What should my steps be to diagnose and fix this?
Check power steering fluid level? Check all rad hoses and such? Put more coolant in and run the car to try and find the leak?
