I need oil for my car engine. It needs SAE 5W-20.
Is Mannol Energy Ultra JP 7906 5W-20 a good product? I can't find its complete technical data and freezing point. enter image description here
This is the Material Safety Data Sheet but it doesn't show the freezing point. I think freezing point is a good parameter to know if the base oil is good.
For example, this Mannol 7918 Legend Ultra 0W-20 show a -40 °C freezing point (I am not an expert, so maybe I am wrong and please teach me):
Freezing point -40 °C
Also I think the quantity of Ester improve the oil. I can't find how much it has.
According to this website, motor oil is incapable of freezing:
Because motor oil does not crystallize, or solidify, at any temperature, it technically does not freeze. However, motor oil at freezing temperatures will begin to thicken, losing the viscosity that allows the oil to flow throughout and lubricate the engine. This increases the risk of damage to engine parts in cold weather.
Because oil is a petroleum product, it will not freeze solid in cold temperatures, though it will lose its liquid qualities as temperatures fall. For example, diesel oil that is cooled below 0 degrees Fahrenheit will change in color and texture, becoming whitish and solid to the point that it will not flow through the engine. This change is the result of the precipitation of dissolved waxes contained in the oil. Gasoline does not contain these waxes, which is why it is not as sensitive to cool temperatures as petroleum-based motor oils.
It goes on to say:
Another solution to this issue is to use synthetic oil, which, according to the motor oil manufacturer Mobil India, has shown resistance to thickening in cold temperatures as low as -40 degrees Celsius. On the other hand, crude oil will become quite thick and tar-like as it is cooled
I can't tell if Mannol itself is good or bad (because it would be an opinion, which we don't do here), but by looking at the container image:
You can see it meets API SP and ILSAC GF-6A which are both the most current standards for motor oil.
Mannol 5w-20 oil is a synthetic oil for Europe but has ratings for around the world. Your owner's manual should specify which oil but if your cold weather temps are below -35C then consider 0w-20 for -40C operation. enter image description here
  • My owner's manual specify 0W-20 or 5W-20 (in my city I can't find 0W-20). The temperatures here is between -5 °C and 25 °C. Oct 1 '21 at 11:10
  • 5w20 perfect for your range of temperatures.
    – F Dryer
    Oct 2 '21 at 14:08
  • Freezing point shows quality. That's why I need to know it. Oct 4 '21 at 16:29
  • Synthetic oil is better formulated and costs more than regular non synthetic oil with its ability to stick on surfaces longer. This alone should tell you syn oil is better than regular oil.
    – F Dryer
    Oct 5 '21 at 17:37
