Will the 73017 timing chain from small block Chevy fit a 1995 Chevy 4.3 vortec
  • Check with a caliper, the width, pitch etc.
    Sep 23, 2021 at 8:19
It depends on the center distance from your cam to crankshaft. The standard SBC distance is 4.521". For your 4.3, it could be 4.511", 4.516", or 4.521". If your V6 is 4.521" from crank to cam, DOES NOT have a balance shaft, and DOES NOT come with a roller cam (flat tappet instead), this timing chain should work.
