I own a 2002 chevy 1500 4.3l v6 cfsi, fuel to schrader valve on rail, none in cylinders.Could it be clogged injectors?
  • I have spark, it will e Sep 21, 2021 at 15:26
  • No fuel flow through any of the injectors? It's possible that all the injectors are plugged and inoperative, perhaps because the engine sat unused for a long time. But it's much more likely that, with no injector passing fuel, the cause is an electrical fault in the circuit or wiring that controls the injectors' opening and closing. Find or buy a known-good injector, and put it in place. If that injector doesn't pass fuel, the engine has an electrical fault. If that injector does pass fuel, then the other injectors are likely plugged and should be cleaned, rebuilt, or replaced. Sep 21, 2021 at 15:32
    I'd check to see if the injectors are firing before I'd think ALL of the injectors are plugged. Sep 21, 2021 at 15:56
  • Do you own any electrical test equipment?
    – HandyHowie
    Sep 21, 2021 at 16:03
