What is a reasonable approach to charging a 24V battery system from a 12V source such as an alternator? Can I simply use a 12v-to-24V step up converter? Seems I’d actually need this converter to hit 5V or more above the battery rating in order for it to work, so maybe a 12V-to-29V nominal.
If the system was in a trailer with 7pin tow vehicle connector, should I disconnect the power wire coming from that connector from the trailer’s 12V panel and run it directly to the batteries via the step up converter? And likewise, disconnect the negative wire from the chassis and run that to the converter’s negative port?
The rationale for doing this is improved inverter efficiency that comes with 24V to 120V as well as doubling solar wattage for a given capacity MPPT. This trailer needs to have a very large battery capacity (400Ah @ 24V), a very large Solar Array input (1400W) to be able to run 120V appliances/tools. 12V appliance use is minimal so I am not at all concerned about conversion losses going back down to 12V for them. When not in use this trailer is attached to my house grid.
A few more considerations. The grounding system. The existing 12V dependencies all use the chassis as their ground/return so I am guessing I need to connect the chassis to the negative port of the step down converter. Also, what about the trailer brakes and running/signal lights? What do I need to do, if anything, to keep those working correctly?
This is what I have in mind: Victron Energy Orion IP20 12/24-Volt 10 amp DC-DC Converter Non-Isolated, High Power
