Can any of you kindly let me know what Connectors this is and how to remove it ?
I have to remove this connector in order to Access my Throttle body below the engine hood.
Please find the pictures of the underside of the connector.
https://ibb.co/CQ1CnS4
https://ibb.co/mC4vbgY
https://ibb.co/qL8x38G
It Says Delphi PA66-GF30
Kia Picanto 2018 Model.
  • It is not what connector it is but how to take it apart. Can’t be sure as none of your images show - but there will be a clip to lift or press then pull the connector off. Do NOT pull on the wires.
    Sep 13, 2021 at 10:24
  • Add a photo to the underside of the connector.
    – HandyHowie
    Sep 13, 2021 at 10:45
  • Add details of the car make and model.
    – HandyHowie
    Sep 13, 2021 at 10:46
  • In the first picture you can see a slot in the top of the corrector and a T-shaped thing in the slot. Press down hard on the T (e.g. with a screwdriver) and pull the connector over it. When you refit the connector it will click into place to lock it.
    – alephzero
    Sep 13, 2021 at 11:14
  • 3
    @alephzero - That's an alignment notch, not a latch. The latch will be on the underside. Sep 13, 2021 at 11:48
8
Push or pull the gray thingy.
The connector should then unlock.
