I have an opel corsa 1.7dti utility 2005 model. I serviced my car recently and after I serviced the car it wouldn't start. It turned over but it wouldn't start. I primed the diesel filter by pouring some diesel in there, it started and ran for about a minute but then it stalled. I thought it might be the fuel pump but when I phoned the agents for a new fuel pump they said the fuel pump lasts forever on these cars I should rather check the fuel pump control module. This is a very expensive part to replace. So my question is how do I know if the problem is the fuel pump or the fuel pump control module without replacing either one of those?
    You should check the fuel pressure at the output of the fuel pump as a starting point.
    – jwh20
    Aug 19 at 10:01
    You should have made sure the new filter was full of fuel, not just added some... If there is too much air, it starts then cuts out. Re-prime the system to get the air out.
    Aug 19 at 10:12
  • Have you checked if there is a priming procedure for this car? Some cars it is a simple as turning the key on and letting the pump run until the ECU turns it off, then repeating this procedure several times before starting the engine.
    – HandyHowie
    Aug 19 at 11:25
  • Perhaps buying a Haynes, Chilton manual can help if you're a diyer. Subscribing to Alldata or Mitchell provides online factory service manuals at reasonable cost.
    – F Dryer
    Aug 19 at 12:32
  • What enginecode? Z17dtj or z17dth?
    – Martin
    Aug 19 at 15:52
