My 1999 Mercury Sable is over heating and the radiator hose is going flat
1Your first step is to replace the radiator hose. It should not be flattening but when they get old they lose their rigidity and tend to flatten out and block the coolant flow.– jwh20Aug 13, 2021 at 11:46
If the radiator hose is going flat then it lacks coolant. So it will need refilling and bleeding.– Solar MikeAug 13, 2021 at 12:03
Low coolant and/or a major blockage in coolant flow. The water pump is pulling a high vacuum making hose go flat. I’m assuming this is the lower hose going flat?– zipzitAug 13, 2021 at 18:55
