I purchased a 30-year-old truck, which seems to run well in spite of its age. But when I take it to get a smog check, the engineer clips a timing light to the first spark plug and tells me that the timing is off. He says that I have to change the distributor back to the factory default before I can pass the test. But when I set it to the factory default, my truck runs unevenly and seems laggy. I suppose that there may be a problem with the electronic timing advance (it is a Toyota Hilux pickup, 22R-E 4-cylinder, late 1980s). The measured emissions are always well below the average and maximum for my vehicle class, but I'm a little concerned that the emissions might go up after I restore the distributor setting (as I always have to do after the test) to where the previous owner had set it.
This back-and-forth has been going on for a few smog checks. I've been to different places and I have never been able to get a clear explanation of why it is necessary for the smog check to include a check of the vehicle's ignition timing. If the purpose of the check is to make sure that the vehicle's emissions are reasonable, then shouldn't I leave the timing where it is when I drive it?
I think I have heard an explanation along the lines of "some people change the distributor back to the factory default before they get a smog check, so that it passes, and the government wants to prevent this" but the problem is the second part of the sentence; if the government wanted to prevent people from doing something, then why would they require them to do exactly that thing? In other words, if you wanted to catch people who had changed the timing back to the factory default, then wouldn't you be looking for cars where the timing is at the factory default, not for cars where it is different? And if you wanted vehicle owners not to change the distributor before the test, then wouldn't you tell them not to change it before the test, rather than telling them to change it before the test? Maybe that sounds a little confusing, but I'm not sure how else to express the fact that, according to the justification I have been given, the opposite of the correct action seems to be being taken in every instance.
Maybe the question could be phrased most concisely as follows: What is the theoretical scenario that is being addressed with the check of the ignition timing? If you had to write a short story about a guy who is doing something bad and then he has to get a smog check, and the check of the ignition timing forces him to start being good, what would the story's plot be?
