I ran two cans of sea foam through it. I replaced the fuel filter, I cleaned the MAF and idle air control, and I put a new air filter in it. All that made it a little better but the problem is still there. At stops power surges periodically.
Is it the fuel pump?
    Have you checked the fuel pressure? Aug 9, 2021 at 0:49
  • nope. I didn't even know that was a thing. I'll try at the next opportunity.
    – user875234
    Aug 9, 2021 at 0:53
    Any check engine codes being thrown?
    – jwh20
    Aug 9, 2021 at 0:54
  • the only check engine light is from the idle air control which has a small leak. but that doesn't show up until after you drive the car for a few hours and the problem I'm describing happens before the light goes on so I don't know if it will be caught by the check engine light but yeah I can check that too that's a good point I forgot about that
    – user875234
    Aug 9, 2021 at 1:11
