Working on a 63 build I have a custom frame that has 63 c10 mounts but I've found what the vin identifies as a 63 chevy silverado and I'm wondering if the cab will use the same body mounts as the c10? Any cab issues I might face?
  • It should. Back in the early 60's they used a lot of the same parts between the vehicles. I doubt there was any difference in the frames between a C10 and a Silverado (though I don't know for sure). If you're really serious about this, just measure the mounts and see. Aug 7, 2021 at 23:17
  • Measure and you will know. Even make templates to check.
    Aug 8, 2021 at 7:05
