My 2006 Toyota Tacoma v6 is losing profuse amounts of oil although it runs just fine after adding more. I did a comprehensive overhaul several years ago and tuned the valves (ground them and readjusted tapets AKA lifters) but I just lifted the valve cover and redid the feeler gauge test and one (out of 4) tapets on one cylinder has too much spacing between it and the camshaft. The same cylinder (I believe) also fails the cylinder leak down test, the pressure inside the cylinder being lower than the compressor.
Could too much spacing between the camshaft and one of the tapets cause oil to get inside the cylinder from the camshaft chamber under the valve cover?
