I just got my brakes (front and back) done about 3 months ago, so I know they aren’t bad. But when I go to press on my brakes, my steering wheel shakes pretty bad. Any suggestion as to why that may be? I have an 06 Dodge Dakota.
Has the vehicle done this since the brakes were changed 3 months ago? If so, I'd return it to them and have them rectify the issue.
Vibration under braking usually indicates a warped brake disc/rotor. It may be that some other component is causing this such as a failing wheel bearing but it's most likely to be a warped rotor.
