I am rebuilding an engine (which is mainly made of aluminium) And I need to degrease all the parts. I don't have any proper degreaser available but even if I had some, I doubt it would do anything. I found that drain unclogger works nicely but it creates a thin corrosion layer on the aluminium (which can be rubbed away with a sponge).
Is it safe for the engine to use drain unclogger and rinse it off in less than three minutes from application?
