My power steering pump has failed on mentioned ford model and steering is harder but drivable. Is it safe to drive around 1000 miles with this issue, since I have no time to repair it and have already booked a vacation?
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Jul 7, 2021 at 22:34
1 Answer
Yes, no, maybe...
It depends on how it has failed. If the internal seal etc failed so it just does not pump then probably yes.
If the bearings have failed and the pump will break and possibly damage something else then no.
If the pump seizes and takes the belt out, then whatever else driven by that belt also stops.
1Most people can't handle to drive without power steering, so it's not really safe even if nothing breaks/seize.– AsenMJul 7, 2021 at 21:11
@AsenM was driving at 12 years old and power steering was rare then. So knowing to turn when wheels are already rotating saves effort. Jul 7, 2021 at 21:17
I know what you mean mean, but most can't even drive stick. I don't think it will be safe for them to go without power steering apart from that I agree with everything you have said.– AsenMJul 8, 2021 at 17:34
@AsenM was towed in a chevy blazer that had a dead engine - no power steering, no power brakes and it was fine - but I have sufficient strength... Jul 8, 2021 at 17:38
