my AC on a 2000 Nissan frontier has excessive pressure on the low pressure side . The compressor is also not coming on. Is there a high pressure switch that comes on the cuts power to the compressor if there is excessive pressure ? Should I drain some refrigerant from the system to bring the pressure down. I don't think the expansion valve is the problem, because there is excessive pressure even when the system is off. Perhaps the previous owner overcharged it
Can you give some background as to why it has excessive pressure.– HandyHowieJul 2, 2021 at 19:32
I bought the car used and I simply hooked up a gauge to check if the pressure was too low for the system to come on– OscarJul 2, 2021 at 21:19
What pressure are you seeing?– HandyHowieJul 2, 2021 at 21:46
