Manual/hand impact drivers are usually described for use with impact (screwdriver) bits. But can they be used with hex sockets too?
I realize that typically an electric or air impact driver/wrench would be used for sockets, but it would be good to know if the manual driver can also be used in a pinch.
Is it ok, is the manual impact driver simply not able to deliver enough torque, or is it even likely to be damaged by such use?
