03 Honda CR-V. Check engine light just came on. O’reilys scanner gave a long list of readings... wondering if I should try bring it in or figure out a way to narrow it down beforehand.enter image description here
  • Are you having any actual problems with the car, as in rough running, stalling, etc? What made you read the codes in the first place?
    – GdD
    Jun 22, 2021 at 7:04
Two approaches:
  1. clear the list and see what comes back as some are often historical,
  2. check the fuels supply system thoroughly as all those are related - maybe there is one fault and it is triggering all the others.
  • I found out it was the evap filter. Thank you for the information though, I didn’t know there was a history function to the read out that would retain issues from the past.
    – Robert
    Jun 24, 2021 at 19:40
The list you got all look related to having a pressure leak in the fuel tank system, which is letting air in/out. A common reason for this is not putting on the gas cap tight enough, or a failed seal in the gas cap.
A good first place to start is checking/replacing the gas cap. Some shops may have a tool for testing gas caps.
If the car is driving fine, the main hazard with this issue is that some gas fumes could be escaping from the tank.
