Looking for DOT3 brake fluid for a 2009 Toyota Venza. There are several options in store which meet the same base specifications (DOT3, Federal Standard CVSS-116 and SAE J1703) as required by the vehicle's owner's manual.
Eg.
"Certified" (brand) DOT 3 Brake Fluid for $12.99 / 946 mL
"OEM" (brand) SUPER DOT 3 Brake Fluid, All Makes & Models for $15.99 / 946 mL
"OEM" (brand) DOT 3 Brake Fluid, Asian for $17.99 / 946 mL
The latter two mention 260C or 252C on the packaging while the first says "Dry boiling point exceeds 205C", as per the specification.
Is there any actual difference between these and other brake fluids which meet the same standards?
For a commuter (i.e. not racing) vehicle, is there any reason to buy anything other than the cheaper option that meets specifications and just make sure to do regular maintenance and flushes?
