I’ve recently changed my drivers door lock on a 3 door 207 and when I try to lock with remote it one nothing when I use the key it locks and unlocks 3 time and then stays unlocked i’ve tried the ignition for 10 second method and still dose not work dose it matter the lock came out of a 5 door hath……………tia
  • Welcome to Motor Vehicle Maintenance & Repair! Is the "207" a Peugeot? What part of the lock did you replace? The keyed portion or the mechanism which latches the door? May 28, 2021 at 11:50
  • Was the lock identical to the original? Were the wires in the same positions?
    May 28, 2021 at 12:11
  • I’m not sure the replacement was from a 5 door are they different cheers
    – Heath
    Jun 2, 2021 at 15:33
  • Well, you have the old one and the new one - did you check?
    Jun 4, 2021 at 9:29
  • Can you put the old lock back in temporarily, and see if the problem goes away? Sounds like wiring is connected wrong, or the whole key unit is significantly different.
    – Criggie
    Jun 8, 2021 at 0:05
