My 12 passenger ford E350 2007 occasionally (random times while driving for random duration 5 -40 minutes) loses power to the:
  • dashboard
  • stero
  • and windows.
What can be wrong with my car? How do I diagnose what is wrong? How do I fix it?
  • When? Random times, just after starting, going over a bump in a road, at night, when hot, when cold, in the rain?
    – HandyHowie
    Commented May 23, 2021 at 11:14
  • @HandyHowie random times while driving for random duration 5 -40 minutes
    – joe
    Commented May 23, 2021 at 11:29
  • Does turning the ignition off and on fix it? Obviously not while driving!
    – HandyHowie
    Commented May 23, 2021 at 11:36
  • @HandyHowie turning the ignition off and then on does not fix the problem. Hard turning may fix the problem (I am not sure that it really works).
    – joe
    Commented May 23, 2021 at 13:14
Sounds like a loose fuse or fuses or loose connectors somewhere or even broken wires.
Only method is to start checking all the relevant fuses and connectors systematically to find out which is the culprit.
Often, all you need to do is wiggle the wires into the fuse box and if the stereo goes off then you have a clue. this applies to connectors as well.
Lots of patience and being thorough is required.
