I have a 2005 Ford Excursion. It has a parking sensor which beeps when it senses something close to the rear bumper. When pulling a trailer, it beeps every time I put it in reverse. I can turn it off, but it turns itself back on each time I shift into reverse.
My brake controller wiring harness knows when a trailer is plugged in. I would like to tap into this wire, and when it is hot turn off the parking sensor. When I don’t have the trailer, I would like the sensor to work as normal. I prefer not to have a rocker switch because I will often forget to turn it on/off.
What is the name of the component I’m looking for? I want the parking sensor wire to be closed when the input is 0V, and open when the input is 12V.
    What are you going to disconnect with your switch. If you just disconnect a sensor, then some reversing warning systems will bleep at you each time you select reverse to indicate that the sensor is faulty.
    – HandyHowie
    Apr 26, 2021 at 9:09
  • That's a great point, @HandyHowie. I was planning to install this right next to the on/off for the parking sensor, and I want to mimic pressing the on/off button for the sensor. I haven't looked at the wiring yet to see what's available, but I'll be sure to test so I don't make the problem worse. Apr 26, 2021 at 14:48
A relay will do what you want.
Get one with 5 terminals as that has contacts changing to “open to closed” and “closed to open” on power, and that is the functionality you want.
