These are from underside of Mercedes Sprinter close to fuel tank. One goes to the engine, the other to a diesel heater. I think they're too small to the fuel filters or pumps. What are they?
enter image description here enter image description here enter image description here
    Diesel heater? Heats the diesel, or diesel burning heater for the cab?
    – HandyHowie
    Apr 19, 2021 at 7:52
  • Diesel burning heater for the cab and crew area.
    – Stewart
    Apr 19, 2021 at 9:44
    Looks like the pump for an sloppy installed aftermarket cab heater. Do you have two heaters?
    – Martin
    Apr 19, 2021 at 9:55
  • @Martin Just the one heater. 2nd hand purchase. Trying to figure out how it works.
    – Stewart
    Apr 20, 2021 at 5:29
My guess would be that they are electrically operated solenoid valves for shutting off the diesel when the ignition is off. Looks a bit like this in a rubber mount -
Taken from - https://12voltfuelvalves.com/product/12-volt-multi-fuel-shut-off-solenoid-valve/
  • No way are those Original Equipment Manufacturer (OEM) components. Those screws on the heater and the orange wire bundle scream crappy aftermarket / owner add on. It sure looks like a solenoid, but why would someone add that? A pump would make a small bit of sense (say you wanted to run the heater when the vehicle is parked overnight) but that would certainly kill a battery pretty quickly. And that only applies to the aux. heater. Why touch the main fuel supply? Perhaps wacko antitheft application?
    – zipzit
    Apr 20, 2021 at 15:46
if I am looking at the parts you are talking about as you have not circled them, then they could be part of the fuel return system.
  • Do diesels have evaporative emissions control equipment?
    – HandyHowie
    Apr 19, 2021 at 6:51
  • @HandyHowie can you smell diesel when filling your tank?
    Apr 19, 2021 at 6:53
  • That isn’t what I asked. I was asking if they have EVAP. I can’t find any references to EVAP in diesels. Do diesels have it fitted? All references I have found say that diesels do not need EVAP due to the high boiling point.
    – HandyHowie
    Apr 19, 2021 at 6:57
