Here's the story: Last summer I started having trouble starting my 2007 Civic. I'd put the key in, there would be no crank, but I could turn the radio on and everything so I don't believe its the battery. Eventually if I kept turning it, it would start, sometimes it would take about 30 minutes though. Anyways a friend though it was the key transponder so I got that replaced and it started fine for 6 months. A few times it wouldnt turn on at first but after a couple turns it worked. I thought I was through the woods.
Last night the problem came back and it took me 30 minutes to start my car. Same issue. If I recall correctly, the green antitheft symbol came on my dash last summer, but not last night when I was trying to start it. I'm at a loss for what's wrong with it. Anyone got some pointers? I think it could be the starter, ignition starter switch, or something with the antitheft system but I'm not sure.
