In an ingenious way to solve the never ending parking problem, a car with swiveling front wheels was engineered/designed/manufactured; see video clip in link 1927 clip
Anyone know what the car model was, was it mass produced or just a prototype? Basically any information about the mechanism or similar mechanisms is welcome. I've also looked at some patent (google patents) records but did not get any information about the mechanism, or related information.
  • Many Cars back then were standard chassis from one manufacturer with a body from another. – Solar Mike Apr 4 at 5:30
I've no idea on the car but I'd take a stab at how it works.. I think it probably has two steering racks, one atop the other. Each rack connects to only one wheel. In normal use, the racks are separated and locked together and the pinion drives them both in the same direction so rotating the wheel clockwise points both wheels to the right. In parking mode, the racks are brought closer and unlocked in such a way that they are both in contact with the pinion and free to move in opposite directions. Turning the steering wheel increases or decreases the amount of toe in as the racks move in opposite directions
Crude sketch time!
Imagine the central pinion gear moving counter clockwise: the racks will move apart. Now imagine pushing a toothed wedge into each side, forcing the top rack up and away from the pinion, and the teeth on the wedge locking into each rack.. now the whole assembly moves according to what the pinion does to the bottom rack only
Probably also worth mentioning that in that video I suspect there will have been something else going on, with the differential or elsewhere. There is no overall force in any direction for two front wheels rotated so they are perpendicular to the imaginary line from rear diff to front wheel center so you can't get a car to spin by driving the diff normally. You'd have to lock it up such that when driven, one of the rear wheels rotates forwards and the other in reverse. You'd choose which wheels to rotate which way (and by consequence, the rotational direction of the whole car) by using forwards and reverse. This would cause the car to rotate in the road, around a point roughly where the diff is. The entire system would be quite a complex affair I dare say, and you wouldn't see this arrangement on a front wheel drive car because getting around the problem that a cv joint cannot transmit power through that angle would be a very costly exercise.. I can see why such a system would not take off, commercially, because it doesn't seem worth going to that level of effort to solve the "parking problem" when the drivetrain and steering components can be simplified and getting into a tight space can be achieved with several back and forth shuffles. Yes, it means you can get into slightly tighter spaces more easily, but if you're willing to put the effort in you can get into a space about a foot longer than a car with the present system, and if people would be less precious about their cars and do as the Italians do (leave the parking brake off so entire lines of cars can be barged out of the way to make room) it becomes moot
These days this would be easiest to do with electric front wheel drive I reckon, where the motors could be rotated thus and power the front wheels to turn, dragging the front of the car round. It would get easier with full wheel drive if all the wheels rotated, then the car could slide sideways into a space but by and large it's again a level of engineering effort that is unnecessary- my mother's Kia parks itself, after scanning the street for a space it can get into it instructs the driver to engage reverse, it turns the wheel itself and parks itself perfectly in a single back/forwards movement - this problem is being solved in other ways (but really needs solving by "fewer cars on the road")
Physically but not commercially viable (and I have some doubts as to the authenticity of the video tbh)
  • Actually the differential issue is quite easy to solve. If you prevent the differential gear carrier from rotating, the rear wheels will be driven in opposite directions. Forward gears would rotate the car one way, reverse the the opposite way. However it would be hard to control because movements of the rear wheels would be scaled up to bigger movements of the front wheel, in the the ratio length/width of the car. The French had some weird ideas about driving controls long after 1927 (e.g. citroenet.org.uk/passenger-cars/michelin/2cv/gearchange/…) – alephzero Apr 4 at 13:27
  • When I said "quite a complex affair" I meant the system as a whole, in comparison to the adopted route most manufacturers took (FWD, and lots of back and forth shuffling at full lock to get into tight spaces). I'll clarify – Caius Jard Apr 5 at 5:38
  • Incidentally I'm not sure it would be as easy as you intimate, to make a typical open differential drive the wheels in opposite directions; you'd have to lock the ring gear and disconnect the drive pinion from it, and connect it to the differential pinions and drive those instead; this can only happen once every 180 degree rotation of the ring gear, though I suppose if you're going to this level of engineering, a mechanism to disconnect one of the differential side gears or both pinions, so that the ring gear can be rotated into position is not beyond the realms of possibility.. – Caius Jard Apr 5 at 6:08
