I replaced my calipers,pads, rotors, master cylinder, brake mod, hubs on my 2000 Chevy Silverado C1500 when I tried to bleed brakes it would not do anything. No pedal pressure and no fluid when trying to bleed. Anyone have any ideas? Thank you
Did you bench bleed the master cylinder?– JupiterApr 2, 2021 at 20:16
Yes I did still nothing– user63057Apr 2, 2021 at 22:51
If the master cylinder is bled and the piston is moving it will pump fluid through the lines. I suspect air in cylinder or faulty cylinder.– JupiterApr 2, 2021 at 23:24
I suspect you need to pump the brakes up before bleeding to ensure the calipers are fully extended. Once everything is fully in place, you should start seeing brake fluid.– Pᴀᴜʟsᴛᴇʀ2 ♦Apr 3, 2021 at 12:40
