I've just been charged a ridiculous amount for a new vaporizer and a DPF clean. I could have bought an entirely new DPF and vaporizer myself and fitted them at home for less than what I just paid.
Is there anything to be aware of if I were to do this in future? Would I need any specific tools to prime the system after replacement or will the car handle everything for me when it next tries a regeneration? I would assume that since I would be replacing both parts it would just be a case of swapping the parts and everything would be fine.
  • The main issue is that some makes need to reset their cleaning cycles. I don't know if thats true in your case. The rest ought to be straightforward and needs only a generic toolset. I had some bad experience working on the DPF: They are made of stainless steel, I had heavy fretting on the pressure sensor takeoff fitting, almost making it necessary to weld it.
    – Martin
    Apr 2, 2021 at 13:08
