My steering wheel on a Mitsubishi Outlander MY2011 is making a clicking noise that seems to come from right tyre (on a RHD).
All tie rods and bushes have just been replaced, as was the CV Boot. The suspension was also checked.
Here's a video of the noise when driving on an all weather road, while not holding the steering so it's playing from side to side.
The video was shot at night, so it's dark. Other than the spring noise, the louder sound is the steering. https://photos.app.goo.gl/uoKZbRdgnubr418M9
  • I seriously cannot tell what's going on from the video. What are you doing to cause the noise? Are you turning the wheel back and forth? Does the noise happen at the same point in the revolution of the steering wheel (if that's what you're doing)? Please, elaborate. Mar 31, 2021 at 19:51
  • At this point I'm not touching the wheel - it's hands free. The car is moving forward on acceleration, the noise is from the steering as the right tyre goes over the rough surface. Also happens when I go over rumble strips. Mar 31, 2021 at 21:02
  • If the steering wheel is straight and not being moved while the noise is occuring, it's not the steering rack making the noise. The only time the steering rack will directly make noise is when it's being manipulated ... unless it's loose on the car itself (not mounted securely). Other than that, I'd be looking elsewhere. Mar 31, 2021 at 22:09
  • Thanks. I'm having a back and forth with my maintenance guy as I suspect worn steering bushings from corrugations, while he's convinced it's an aging rack and changing the bushes won't resolve much. Will suggest we reopen and check where the rack connects with different points at the bottom. Apr 1, 2021 at 8:52
  • Cv boot replacement won't stop a worn cv joint from clicking.. if deciding whether it's bushes or rack, replace the quicker/easier/cheaper component first
    – Caius Jard
    Apr 4, 2021 at 4:56
Eventually took apart the rack, and the gear was worn. It had free play and also appears the bearing underneath was worn too. Got a salvage sterring gear and rack and the noise is gone.
However, my repair guy was of the opinion that the steering gear was usable for more than 20,000 kilometres and even more. It's worth changing when steering becomes too difficult.
Apparently later model Subarus with electric steering are even worse since they fail faster under rough roads and are at least more than 3 times the cost of hydraulic ones. So the owners just live with the noise.
