The white object in the photo was found in a place where a car was parked.
Is this a car part?
In case it would help, the parking place was in a country guesthouse, so maybe it's a piece from other machine.photo of unknown item
  • Welcome to Motor Vehicle Maintenance & Repair! Mar 22, 2021 at 0:19
  • Looks like some sort of sifter or filter to me. The cog (gear) with the hole in the center indicates that it might be designed to spin along the z-axis. The edges, on the other hand, look more like they lock in place. Can you spin the center? Does it smell of anything? Mar 22, 2021 at 1:46
  • Doesn't look like any car part I've ever seen.
    – GdD
    Mar 22, 2021 at 8:25
  • @RockPaperLz-MaskitorCasket good points but it is not in my possession, countryhouse owner sent my the photo after we left the place. I also think that it could be a kind water pump filter, or maybe a ventilation grill in a motor.
    – Pin
    Mar 23, 2021 at 10:43
  • My best guess is a grain sifter or a honey filter, but I'm really not sure without a closer look. Mar 23, 2021 at 12:25
The piece is a washer fluid tank filter from Skoda Scala. It should be placed by error during fabrication process somewhere inside because my car has its own piece in correct place.enter image description here
After almost a year and a half, mystery solved.
